Question on cylinder size for DIY honda powered splitter
Northeaster1 Posted By Northeaster1, Nov 22, 2010 at 3:42 PM
Thread Status:
  1. Northeaster1
    Northeaster1
    New Member 2.
    NULL
    Oct 10, 2008
    119
    0
    Loc:
    Nova Scotia
    The father-in-law and I are going to build a splitter in the next couple of months. We usually rent one from a friend of his. It may seem small, compared to the talk here, but there is nothing it hasn't been able to split, and the two-stage pump only kicks in if you get into some narly, twisted stuff, or a big knot.
    the rental one has a:
    - honda 5 hp
    - john barnes 2 datge pump (I believe about 11gpm)
    - 3.5" cylinder with 1/5" rod, 24" long.
    As we already have a 4 hp honday engine we can use, we are planning on just getting the same size pump and cylinder, as the one we have been renting. I realize they say you need 5 - 6hp for an 11gpm pump, but our experience with it says that the 5 hp honda is only running about mid-way (or less) between idle and full throttle, so we figure that the 4hp should be fine, with the engine revving a bit higher.
    Any problems with our thinking?
    I am sure the cycle time would be faster with a bigger pump, and engine etc but the 4hp is free, and the rental one seems fast enough for us.
    We are planning to make it horizontal only (have strong back / weak mind and a wood hauler with lift for the really big stuff) and I like working at waist level, with the side tables.
  2. Jamess67
    Jamess67
    Feeling the Heat 2.
    NULL
    Nov 19, 2007
    358
    4
    Loc:
    Central Illinois
    I wouldnt go any bigger than a 4x24x2 cylinder. Any more than that with a 11gpm and your looking at long cycle times.
  3. Northeaster1
    Northeaster1
    New Member 2.
    NULL
    Oct 10, 2008
    119
    0
    Loc:
    Nova Scotia
    Yes, as mentioned I will likely buy the same type / dimensions of cylinder that is on the rental one we have used a few times. It is 3.5 x 24 x 1.5 and seems to split anything we can find. Cycle time on it is acceptable, but like you say, I would not want to go bigger, and slower, unless I went with a bigger pump. (and engine). Where the father-in-law has a honda 4hp just sitting there, and we have been happy with the rental unit's performance, I think this will do us.
Thread Status:
