Question regarding burn indicator on double wall stove pipe?
sir splitsalot
19
Southern Ontario
Does anyone know of an alternative position for the burn indicator, as it says that you can only use it on single wall pipe, mounted 18 inch above stove top. I have double wall. Just wonder if you can mount else where and if so what the temps should be?
Thanks in advance.
Thanks in advance.
On double wall you need probe type.
Thanks in advance.
I agree you need a probe.
Double wall pipe should have a probe thermometer for accurate results . . . that's the bad news.
The good news is that as North pointed out you can use this thermometer on your stove top.
