I finally have my radiant floor heating system integrated with my well water. First off, my radiant floor system was design and installed to allow potable water to be run through the floor (stainless steel & bronze pumps versus cast iron, etc.). The heat is added by a water to water HX in a 1000 gallon storage tank and/or from in-line instant water heater (if storage is not adequate).
I added a bypass that routes all of my domestic water use (personal and irrigation) through one of the floor zones. When running a sprinkler for irrigating small paddocks I run about 3 GPM. This is irrigation I have to do anyway for our goats and chickens. The head loss to run it though 7x300 7/8" radiant loop is negligible.
Running the 55F well water through the floor at approximately 3 GPM has lowered the floor temperature by 1 to 2 F. It is a 1500 SF zone so the BTU potential is around 8 to 10,000 BTU. This is equivalent to a basic window air conditioner. The basement below the radiant is dehumidified anyway so condensation is not a problem (one of my biggest concerns, but proper humidity management makes it a non problem). I'll be adding some temperature monitors to measure the delta-T in the floor but as of right now it is working as planned for just the cost of some plumbing fittings.
It costs me about 0.08/hour to pump and distribute 3 GPM. This is about the same cost as a 10,000 BTU window unit. Since I am irrigating anyway this is free cooling. Now to figure out if adding a 300-600 LF ground loop and a circulator would have any reasonable payback period.
