With all the money in spare parts I'm starting to question the money saving and efficiency of pellet stove.
Well I have some spare parts on hand but luckily have never needed any. You don't need to stock any if you have a backup heat source. All stoves will at sometime break down, just like cars. Once you get into burning pellets it just drives most of us nuts when we hear the oil burner kick in so we fix our own as quickly as possible.
I have zero spares, I know my 25 will have no issues this year :fingers crossed:
I am having a carbon build up issue on the end of my auger tube that was never this bad though.
I might have to adjust the auger out a bit into the burn box.
4. Combustion or Exhaust blower? Original or Upgraded?
And turn on TV to see the FedEx truck that has your parts rolled over somewhere in Texas. Happened to me with a new phone. Needless to say the 3 day service turn into a bit over 2 weeks.I'll just turn on the oil furnace until parts can be ordered and installed.
Oil tank is full. I can wait.And turn on TV to see the FedEx truck that has your parts rolled over somewhere in Texas. Happened to me with a new phone. Needless to say the 3 day service turn into a bit over 2 weeks.
The Gleason Avery Open Frame Ball Bearing Motor which is 1.75 Amps is the best choice! That is what I run in my quad and I hardly ever need to clean ashes out of the fire pot!
To find it, Just Google:
low drafter kit quadrafire
have you ever used that gleason avery as a replacement for the srv7000-602?
is it just that the housings are different and the motors are the same on the OEM parts?
Yes in my quad Contour and it is burning so much better! ! !
HHT who owns Quadrafire found a new vendor in China for all their OEM blowers call Huayi.
Their specs are the absolute minimum able to run their pellet burners. I have seen them first hand. The exhaust blower that takes so much time to spin up to speed reminds me of flooring the gas peddle of a voltswagon rabbit and bearly getting across a busy intersection!
ok, at the risk of totally annoying you, the part number for the countour motor (and the heatilator PS35) is 812-4400
and the number for the PS50 motor is srv7000-602. so that still leaves me wondering. i guess if it was supposed to work in the PS50 they would have listed it. i'd buy one if i could verify it would work and was safe. there must be some reason they don't say it replaces the OEM for the PS50.
what's in my stove now shows as 1.04 amps, but that is probably similar to whatever is used in the PS35. i still have a suspicion that they are both the same motor. but i really need verification before i change this out.
i guess i'll ask my dealer. though he will likely say i should get the OEM. i'll try and press him to check if the two heatilators actually use the same motor.
screenshot from eastcoast hearth doesn't list the PS50 (srv7000-602)as one of the stoves that upgrade kit works for.
thanks, Don. i really don't mean to be a PIA about this. but i also am not comfortable just assuming.
I have a Harman Invincible RS, I do not need spare parts...........
I had to put a new exhaust blower in an RS a few months ago. The ESP probes also fail on those and then the blower does not shut down. I also like to upgrade them to auto ignition too.
