"ready to use" fuel
HardWoodW Posted By HardWoodW, Oct 7, 2010 at 12:22 AM
Thread Status:
  1. HardWoodW
    HardWoodW
    Member 2.
    NULL
    Oct 9, 2009
    76
    16
    Loc:
    Indiana
    I went to the small engine warehouse today to get a new chain for my saw, and they had 50:1 "premixed" fuel. The guy told me it's ethanol free so it's better for the carburetor and wouldn't damage your saw if you let it sit in the tank for a while. Claims to have a shelf life of 2-3 years. Well it's $20 for a case of 6 32 oz bottles so I passed since I can mix that much fuel myself for about 5 bucks but if I thought it was a lot better for my saw I guess I would use it. Anybody use this stuff?
    http://www.drillspot.com/products/1348517/32OZ_50-1_Fuel_Oil_0125638_32OZ_50-1_Fuel_Oil
  2. HittinSteel
    HittinSteel
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    1,587
    409
    Loc:
    Northeastern Ohio
    It could certainly have an application for convenience.
    I prefer to run 93 octane with ethanol (no choice locally), Stihl Ultra and little shot of seafoam.
    The Stihl Ultra has fuel stabilizer as does the sea foam. I mix just enough to last 30-60 days and if I haven't used the balance I dump it in the mower or truck and mix a fresh batch.
    I wish I could buy non ethanol gas, but I think there are ways to handle it without paying the price of the premixed stuff.
  3. bogydave
    bogydave
    Minister of Fire 2.
    NULL
    Dec 4, 2009
    8,426
    3,446
    Loc:
    So Cent ALASKA
    Thats pretty expensive to me but I burn regular unleaded for years in my coleman camping equipment.
    (I'm a cheap-skate though :) )
    $20 for 1-1/2 gallons. WOW.
    Better for their bank account than your saw.
    Good marketing ploy & a high profit gig.
    May have some buyers but they won't be "do it yourselfers" or very many woodcutters.
    Aviation gasoline I think is ethanol free. Buy a 5 gallon can & "sea-foam" or "sta-bill" it. Should last a year+ in a good can.
    Check small airports, some have it in sealed cans. More $$ than at the pump but high octane & ethanol free. Mix a gallon at a time.
  4. backpack09
    backpack09
    Minister of Fire 2.
    NULL
    Sep 10, 2007
    554
    7
    Loc:
    Rochester, Mass
    I am currently running 117 Octane Leaded VPRacing C16 in my saw. It runs about 8$ a gallon, never goes bad, and has no alcohol in it. And SMELLS awesome while you are cutting.
  5. Bigg_Redd
    Bigg_Redd
    Minister of Fire 2.
    NULL
    Oct 19, 2008
    4,153
    995
    Loc:
    Shelton, WA
    For nearly unspoilable gas that that costs only about $.50 per gallon more than premium follow these 3 easy instructions
    1) Go to your local airport with a 5 gallon metal gas can (metal can keeps AvGas indefinitely)
    2) Dump one pint of your favorite mix oil in the 5 gallon metal gas can (makes 40:1 which just makes the math easier. If you wanna do the math for 50:1 go right ahead)
    3) Fill gas can with 100LL (100 octane leaded AvGas)
  6. smokinj
    smokinj
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    15,981
    1,412
    Loc:
    Anderson, Indiana
    +1
  7. mkt1
    mkt1
    Member 2.
    NULL
    Nov 8, 2009
    65
    3
    Loc:
    Central, Ok.
    But when useing LL100 leaded gas the newer saws have a catalist in the mufflers, and lead will stop them up. Soo can you remove the catalist without causing performance problems ????
  8. amateur cutter
    amateur cutter
    Minister of Fire 2.
    NULL
    Aug 20, 2010
    1,170
    714
    Loc:
    West Michigan
    Toss the catalyst in the trash, open the muffler up a bit for more exhaust flow, remove the limiters on the mixture screws, re tune the saw, & you'll be surprised at what your saw will do. Catalyst = constipation = heat build up= death to an engine. Not to mention low performance. A C
  9. bogydave
    bogydave
    Minister of Fire 2.
    NULL
    Dec 4, 2009
    8,426
    3,446
    Loc:
    So Cent ALASKA
    Husqvqrnq manual for the new saws state:
    Use good quality unleaded or leaded petrol.
    • CAUTION! Engines equipped with catalytic
    converters must be run on unleaded fuel
    mixtures. Leaded gasoline will destroy the catalytic
    converter and it will no longer serve its purpose. The
    "green fuel cap" on saws fitted with catalytic converters
    means that only unleaded gasoline can be used.
    • The lowest recommended octane grade is 90 (RON).
    (so "leaded" or "unleaded" is ok for most Huskys)
    Stihl manuals state:
    Use mid-grade unleaded gasoline with a
    minimum octane rating of 89 (R+M/2).
    STIHL recommends that you use only
    nationally recognized high-quality
    unleaded gasoline!.
    This may not be true on all newer saws, but the octane is important. Regular unleaded burns hotter & is harder on the bearings than premium unleaded.
    For unleaded only saws;
    A_C might bet right, "open it up" but "wait until the warranty has expired anyway." :)
    So av-gas is OK for most saws. Just check the manual or risk voiding the warranty. No ethanol, which is good.
    Just store it in a tight metal can for longer shelf life.
Thread Status:
