I'm in a beautiful log cabin that has a nice heating system where I have a wood burning furnace tied into my oil burning system ....I have not lived there in the winter as it's my Summer cabin , but the last owner lived there full time ...It's a great place , but I am not thrilled with the way the wood burning section works ....The heat comes up in the firebox, and once a certain temp is reached , the fan kicks on and the house heats ....The problem is that the fan will continue to stay on until the heat in the firebox goes lower and then it cycles on and off till it finally stops altogether ....The heat goes throuout the house which is really nice, but it gets too hot !!....To the point of openning windows !!...There is a basement where the unit is . and there is also a small duct opening in the main duct to allow heat to go into the basement, but that also gets really hot ....The heat is very hard to regulate and what I would like to do is put a small wood stove in the fireplace in the living room ....The cabin is only about 1300 sq ft , and once it's warm , it really stays nice .....The problem with putting a wood stove in the fireplace is that it's only 28 inches high !!.....It's a beautiful stone fireplace that runs clear up to the peak of the roof where I think I should have no problem with flue length, but I need to find a stove that has a rear outlet flue that the top of the pipe is only 27 or 28 inches off the floor ........Is there such a stove ? ..... I was looking at the Englander stoves which I would have to put in with a shoehorn ....I was thinking that the 13NC would fit nicely in the fireplace , mainlly because I thought it was shorter than the 30NC ....Wrong again
I would like to start a fire to get the house warm using the larger wood burner in the basement, and then continue heating the house with the wood burner that I am trying to put in the fireplace in the living room .... Any ideas for a stove for my 28 inch high living room fireplace ? .....Thanks, Jim
..... I would like to start a fire to get the house warm using the larger wood burner in the basement, and then continue heating the house with the wood burner that I am trying to put in the fireplace in the living room .... Any ideas for a stove for my 28 inch high living room fireplace ? .....Thanks, Jim
