After doing a lot of reading, I'm can't get the long burn times, thermostatic control, and even heating of the BK out of my head. There's a used on for sale "locally" that's only 2 years old. I know with a cat stove, there's greater risk of it having not been operated properly, but I suppose I could inspect the cat if I were to go look at it. From my other thread, https://www.hearth.com/talk/threads/hearthstone-mansfield-1995-vs-2015-vs-something-else.149429/ , here's the basics on our situation:
So I have a couple of questions:
1. He is asking $2000 for a used "Classic", but I think it looks like a Parlor. I also feel like $2000 is way too much, but probably less than a new one. What do you think? I was thinking half of that, but maybe he overpaid himself and thinks it's made out of gold. It's been for sale for a month though...
2. I'm not sure if it's a Princess or a King. Is there an easy way to tell? A Princess may be sufficient, but I think a King would be nicer.
3. Are Blaze King warranties transferable? I suppose the warranties aren't that long to begin with, and I don't mind welding/bricking/gasketing this thing a few years down the road if needed.
pvfjr said:We bought a house a year ago, and I'm finding our current wood stove's performance inadequate. We have a 2200 sq ft house with two stories. The stove is in the extreme corner of the house in the living room, nestled between two exterior walls. The pipe/chimney run is straight up, and probably tops out at 26' off the ground. It's on the windward side of the house (west), with some trees around. Sometimes I think this causes some positive pressure outside that gives us draft troubles when starting up cold, but it's fine after a few minutes.
The main problem is the inability to achieve long burn times, and the lack of heat distribution in the house. This thing will chase you out of the living room, but the entire upstairs is cold, and the rest of the house stays cool. The house doesn't have a very open layout, and I think the transom of the living room is blocking the heat flow. The firebox lacks height; I can't stack two 5" splits in there! This stove is just too small for this house. Maybe they just purchased it for ambiance? We have a modern gas furnace with forced air, but would prefer to use it sparingly.
