    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. onetracker Minister of Fire
    rondout valley ny
    greetings
    i have a regency i2400 which i inhereted with the house. inserts generally have sucky efficiency but it heats my house well enough. i also inhereted a big free standing regency that is in my basement/shop. i notice that when i close the draft on the free standing stove, the flame really diminishes and i get great sweeping blue secondaries. but when i do the same on the insert, it only marginally diminishes the flame. my overnight burn times SUCK cuz it won't shut down adequately. i'm warm as hell but burning waaay too much wood.
    my question:
    is there a way to get to the draft rod/paddle to see if its warped or adjustable?
    appreciate any insight on this
    medium regency wood insert
    big regency free-standing (in basement/shop)
    small regency free-standing (in wife's studio)
    monitor kerosene heater
    a few stihls (362, 290, 180)
    small husky (435)
    old poulan pro (won't quit)
    oregon 22-ton splitter
    6/8/12 lb mauls
    Full Blown Cordwood Junkie
    (temporarily revised to Severe Wood Addict :cool: )
    onetracker, Yesterday at 12:53 PMEditReportBookmark
    #1Reply
    :cool:
    #1
    Helpful Sponsor Ads!
  2. Postalizer Member
    Central CT
    The first thing I would check is to make sure the door gasket and the window gasket are making
    good seals and not leaking by. Your door handle may need adjustment to make up for
    the door gasket compressing.
  3. onetracker Minister of Fire
    rondout valley ny
    you know what? my gaskets are pretty new but i'm gonna re-do them anyway.
    thanks for the heads up.
    anyon else run into this problem with a a regency insert?
    thanks in advance.
    OT
  4. begreen Super Moderator
    South Puget Sound, WA
    The Regency 2400i is the same inside as the Hampton HI300. Most folks report good burntimes with this insert.
    Examine the air control assembly to make sure it is operating correctly. Look for sloppiness in the air valve. Also, make sure that the two baffle bricks are in good condition and seated in place correctly, all the way to the back of the stove. Check the door gasket with the dollar bill test before replacing. The door latch tightness is adjustable by removing washers.
  5. Woodreb New Member
    NW CT
    After the first year with our Regency i2400, I found that the door wasn't sealing too well and we were burning through a load rather quickly. Removed one washer from the door latch and it made all the difference in the world.
    I also find that the 2 nuts that hold that door latch tend to loosen from opening and closing the door over time and keep a wrench handy to snug them up occasionally.
  6. onetracker Minister of Fire
    rondout valley ny
    the gasket is new and the door seals tightly.
    begreen...how do i get to the air control assembly?
    thanks everyone for the help.
