Regency Insert
It's a good heater that will warm the house even without the blower on. I don't think I have read a bad review.
Reactions: Bassman123
It is a rather small unit. I would not expect burn times over 6 hours. How many sqft do you want to heat and how well is your home insulated? Is it for supplemental heat or primary heat?
As any modern stove/insert it will require dry wood with an internal moisture content of less than 20%. Did you already take care of that?
!000
1000sq ft downstairs and 300 sq ft upstairs. Using it for supplemental heat. I am all stocked with wood I have been seasoning for 1-1.5 yrs
If the insulation is good (and no cathedral ceiling etc.) that should heat it but as I said, don't expect meaningful heat after 5 to 6 hours top. Kudos on the wood. :)
Any particular reason you are not looking for something larger? What happens quite often is that members here look for a supplemental heat source, buy a small unit, then discover how much they like the wood heat and then trade up to a larger model.
Are you getting a full insulated liner?
Even for this "stove/insert" a block-off plate is recommended to help with heat retention: https://www.hearth.com/talk/wiki/make-a-damper-sealing-block-off-plate/
If the fireplace is at an exterior wall putting some Roxul insulation in it may also help with keeping the heat inside.
