Relationship between chimney draft and height
dafattkidd Posted By dafattkidd, Oct 11, 2013 at 12:21 AM
Thread Status:
  1. dafattkidd
    dafattkidd
    Minister of Fire 2.
    NULL
    Dec 11, 2007
    1,733
    332
    Loc:
    Long Island
    Hey,
    Admittedly my install is not bulletproof. I have about 14 feet from the bottom of my unit to the top of my chimney so probably like 12" of actual chimney liner. My insert heats fantastically, efficiently and burns cleanly. I try to burn good dry wood as best as I can.
    My problem is every time I open the door I get smoke in the house. And not just a a quick whiff, like it pours in the room. I have an offset box that attaches the insert to the chimney. I'm fairly sure the offset box is the culprit, but it's a necessary evil without extensive masonry work. Last year I replaced the offset box and used furnace cement to seal any suspicious air gaps. It had no improvement.
    Here's my question: will increasing the length of my chimney by 3 feet help?
    Here's my version of the math: 12 ft chimney + 3 ft (25%) increases draft by 25%. Is this correct? Will adding three feet really increase my draft and help with this? And if so what is the best product to transition a 6" SS flex liner to class A chimney (or whatever is best here)? Thanks so much.
  2. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    I'm no expert on this, but I have heard that it is that kind of direct proportion. A 25% increase in chimney height should help a lot. I'll leave the rest of the question to others.
  3. oldspark
    oldspark
    Guest 2.
    NULL
    3 feet will help and if you need it add another 3 feet if you are not happy with the first 3 feet, might have to support is but sounds like the best solution for what you have, I have 18 feet total straight up and never get smoke back into the house.
    Maybe buy a section of 4 feet to give just a little more height, maybe more bang for your buck too.
    dafattkidd likes this.
  4. Woody Stover
    Woody Stover
    Minister of Fire 2.
    NULL
    Dec 25, 2010
    8,252
    2,334
    Loc:
    Southern IN
    Stick a piece of stove pipe up there to see what happens.
    How much minimum stack height does the manual call for?
    HDRock likes this.
  5. Bluerubi
    Bluerubi
    Burning Hunk 2.
    NULL
    Nov 26, 2012
    140
    49
    Loc:
    Auburn, NH
    What type of cap do you have on your liner? Mine was the original round one that came with the kit that had a bunch of slits in the metal to keep out critters. Draft was pretty good, but after replacing it with a giant cage that covers the whole top of my chimney I've been battling with too much draft, even in warm temps outside. Thinking back I had about 28 square inches of cross sectional area in my liner, that was choked back to a fraction of that due to the restrictive cap, so I guess I shouldn't be surprised that it pulls a lot stronger now that it's wide open.
  6. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,499
    6,074
    Loc:
    Northern IL
    Three feet can have drastic effects in some instances. I can tell you that a 2 ft extension to mine virtually fixed an occasional backdraft issue (due to house layout and prevailing winds, not length of flue). Grab a cheap piece of galv. snap together stuff used for venting. Stick in on top of what you have. This is a cheap (and very temporary) way to test your theory.
    HDRock likes this.
  7. oldspark
    oldspark
    Guest 2.
    NULL
    Do you have a link to that product, sounds interesting.
  8. AnalogKid
    AnalogKid
    Burning Hunk 2.
    NULL
    Oct 22, 2012
    229
    144
    Loc:
    CT
    Is your liner insulated? I had a big concern last year when I decided to install my insert. My chimney is very short, 12'5" from firebox floor to top of chimney. Mfg told me they recommended 15' at a minimum. I took a gamble, and with the advice of guys on here, I insulated the heck out of my liner. I have outstanding draft and zero spillage.
  9. dafattkidd
    dafattkidd
    Minister of Fire 2.
    NULL
    Dec 11, 2007
    1,733
    332
    Loc:
    Long Island
    I'm almost positive it calls for 15" chimney.
  10. dafattkidd
    dafattkidd
    Minister of Fire 2.
    NULL
    Dec 11, 2007
    1,733
    332
    Loc:
    Long Island
    I have insulation at the top foot and bottom foot of an interior chimney.
  11. dafattkidd
    dafattkidd
    Minister of Fire 2.
    NULL
    Dec 11, 2007
    1,733
    332
    Loc:
    Long Island
    Just 6" galvanized chimney like on an oil burner? Will that really give me a pretty accurate idea of the effects?
  12. AnalogKid
    AnalogKid
    Burning Hunk 2.
    NULL
    Oct 22, 2012
    229
    144
    Loc:
    CT
    How much of a chore would it be to pull your liner? It may be worth a shot to do a double-wrap on your liner. I bet it would help.
  13. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,499
    6,074
    Loc:
    Northern IL
    Yep - the $3.00 per 3 ft stuff at the box store. It will simulate (temporarily) a 3ft extension of pipe well enough to give you an idea if it will work or not.
  14. MDFisherman
    MDFisherman
    Burning Hunk 2.
    NULL
    Sep 17, 2012
    154
    33
    Loc:
    So. MD
    I added a 1ft "dirt leg" I will call, it to the bottom of my flue at the cleanout tee, as the manufacturer recommended. Do you count this in the overall height of the flue? what about the pipe inside the house, does the vertical run also count toward the overall flue length?
  15. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,499
    6,074
    Loc:
    Northern IL
    Overall length is usually figured from the Top Base of the stove, to the Top of the pipe where the cap attaches.
  16. mellow
    mellow
    Resident Stove Connoisseur 2.
    NULL
    Jan 19, 2008
    4,750
    654
    Loc:
    Salisbury, MD
    Per ICC: The height of the chimney shall be measured from the firebox floor to the top of the chimney flue.
  17. mellow
    mellow
    NULL
    Jan 19, 2008
    4,750
    654
    Loc:
    Salisbury, MD
    Those offset boxes are horrible, but in some cases it is a nessary evil.
    If adding the 3 feet of pipe doesn't work you could look into getting an Enervex Fan to help your draft.
    [​IMG]
  18. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,499
    6,074
    Loc:
    Northern IL
    Yep - looks like from the base (thanks Mellow). This from the Quad instal manual.
    Chimney Height / Rise and Run
    This product was designed for and tested on a 6 inch
    ( 152 mm) chimney, 12 to 14 feet ( 420 - 480 cm) high, ( includes
    stove height) measured from the base of the appliance to
    the the top of the chimney ( not including chimney cap) .
  19. dafattkidd
    dafattkidd
    Minister of Fire 2.
    NULL
    Dec 11, 2007
    1,733
    332
    Loc:
    Long Island
    If that's case then my chimney height is closer to 13, but I'm telling you the offset box really makes a mess of things.
    I'm going to try the test once it's cool enough to start burning.
    Does any one know if there is an equation or a rule of some sort which specifically outlines the relationship between height and draft? Just good to know.
  20. mellow
    mellow
    NULL
    Jan 19, 2008
    4,750
    654
    Loc:
    Salisbury, MD
    It would probably need to be converted into bars of vacuum, which you would need to have a meter to test.
  21. dafattkidd
    dafattkidd
    Minister of Fire 2.
    NULL
    Dec 11, 2007
    1,733
    332
    Loc:
    Long Island
    I would honestly prefer the fan over the extended height. The extra pipe coming out of my chimney will look ridiculous. I am almost positive I have read Begreen express serious reservations about draft induced fans. Any feedback on the fans?
  22. oldspark
    oldspark
    Guest 2.
    NULL
    "Taller chimneys usually produce stronger draft. A rule of thumb for minimum height states that the total system height (from the floor the appliance is mounted on to the top of the chimney) should never be less than 4.6 m (15 ft.). Most normal installations exceed this height, but installations in cottages with shallow-pitch roofs may not. If draft problems are experienced with short systems, consider adding to the chimney height. If draft problems are experienced with systems higher than the recommended minimum system height, adding to the chimney may have little or no effect. Most draft problems have to do with inadequate gas temperature in the chimney"
  23. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,499
    6,074
    Loc:
    Northern IL
    Sparky - you bring up a good point. We haven't had the discussion yet on run temps. What kind of temps are you running at when you experience the spillage?
  24. dafattkidd
    dafattkidd
    Minister of Fire 2.
    NULL
    Dec 11, 2007
    1,733
    332
    Loc:
    Long Island
    Thanks for that. Where is that from?
  25. mellow
    mellow
    NULL
    Jan 19, 2008
    4,750
    654
    Loc:
    Salisbury, MD
    I will say that I got smoke spillage from my insert until I pulled my flex liner and put insulation on it, but I have a few differences, exterior chimney, no offset box, 23 ft tall chimney.
Thread Status:
