Time to replace two sump pumps in a sump that produces a ton of water. Two 3/4 hp submersible pumps running in the same sump can just keep pace with with the inflow after a 3 to 4 in. downpour. This amount of water doesn't happen but once in 3 or 4 yrs but when it does it is a problem! These pumps are rated at 3500 gal/hr each, at 10ft lift. Can anyone recommend a reliable pump with this type of capacity? What brands have you had good luck with? Has anyone used one of the pumps with electronic off/on device like the Switch Genius Technology Wayne Pumps markets.They have no moving parts. With two pumps in the same sump I have a minimum amount of room available. Float switches can be a problem.
Thanks
Tom
Thanks
Tom
