Removing Creosote From Painted Surfaces
BulldogAcres Posted By BulldogAcres, Mar 1, 2012 at 6:40 PM
  1. BulldogAcres
    BulldogAcres
    Member 2.
    NULL
    Feb 12, 2010
    61
    2
    Loc:
    Northeast Washington State (Colville)
    I have a problem removing Creosote from painted surfaces. I use Acetone to remove Creosote from unpainted surfaces, but it will take the paint off painted surfaces. Does anyone have a good way of removing Creosote from Painted surfaces.
  2. Gasifier
    Gasifier
    Minister of Fire 2.
    NULL
    Apr 25, 2011
    3,152
    794
    Loc:
    St. Lawrence River Valley, N.Y.
    I use a hand soap from one of those pump dispensors with hot water and a green dish scrub pad. Seems to work fairly well. Some elbow grease is required. But I do not have that much creosote outside my firebox. Have a good one.
  3. mole
    mole
    Member 2.
    NULL
    Oct 23, 2008
    158
    17
    Loc:
    Western NY
    You might want to try some ethanol (denatured alcohol) if the soap doesn't work. It'll probably dissolve the creosote (I haven't tried it for creosote specifically), but it's a lot more gentle on paint than acetone. A mix of isopropyl (rubbing) alcohol and water might work as well.
  4. muncybob
    muncybob
    Minister of Fire 2.
    NULL
    Apr 8, 2008
    2,120
    287
    Loc:
    Near Williamsport, PA
    Speedy White Hearth and Stove cleaner has worked well for me.
  5. walkerdogman85
    walkerdogman85
    New Member 2.
    NULL
    Feb 21, 2012
    59
    7
    Loc:
    ohio
    i was wondering how to remove creosote from the brick on my chimney
