    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. jomama New Member
    Thurman NY
    Can someone please tell me the diameter and length of each of the gaskets used on a Resolute I model?. Much appreciated.
    #1
    Helpful Sponsor Ads!
  2. raybonz Minister of Fire
    Carver, MA.
    Send a PM to BrowningBar he knows lots about these stoves..
    Ray
  3. defiant3 Feeling the Heat
    No. NH
    5/16" for door. The griddle depends: If it's a"raised griddle", that is it doen't sit flush w/ the top, then use the same 5/16". If it's a flush griddle, then get the fancy 5/16" armorseal stuff with the meatal wound around it. Armorseal doesn't work w/ raised griddle, but standard gasketing can work w/ flush graiddles. Just deosn't last as long. Is there glass? Use 5/8 or 3/4 adhesive tape. With the cast panel, 1/4" regular rope works fine. Careful removing old stuff, as they were still using asbestos in those days!
