I am thinking about installing a reverse osmosis system for our drinking water on our well. Our water straight from the well is absolutely horrific. we have it go through a chlorinator, then through a backwashing carbon filter to remove the chlorine and then through a softener and finally through a whole house filter.
that setup removes the nasty sulfur smells, the iron, etc but our wonderful water also has high levels of sodium which is very undesirable for us.
im sure it must have some other things RO would remove too... its disaster water but it didnt have any harmful bacteria in it - the chlorinator is there to help with the crazy high iron content.
any thoughts on a 5 stage RO system?
if you own one, how does the water taste? like bottled?
how often for filter replacements? particularly the membrane.
are you generally happy with it or regret the purchase?
i'm ok with the wastewater, i can pipe it to my sump pump and i know these things require a lot of pressure, but i have good pressure (40/70psi)
