Roof Vent Stack Boot Question
n1st Posted By n1st, Jun 22, 2008 at 2:25 AM
Thread Status:
  1. n1st
    n1st
    New Member 2.
    NULL
    Jun 3, 2007
    121
    0
    Loc:
    Enfield, CT
    My vent stack boots are in very bad shape and the rain must have been combing into the attic. The pipe was 3", so I bought a 3" to 4" rubber adaptor from Lowes and put it down, I think it should work. Anybody else try this? The alternative is to remove the boot (and plate) from shingles and replace.
    I have a 2" vent stack also. This one doesn't look to be leaking yet. I don't think there is a 2" to 3" adaptor readily available, so I'm looking for ideas.
  2. wahoowad
    wahoowad
    Minister of Fire 2.
    NULL
    Dec 19, 2005
    1,630
    132
    Loc:
    Virginia
    I don't know the various sizes available. Just adding my 2 cents that mine leaked (they dry rotted and leaked when it rained) and I bought a replacement boot, slid it down over the existing one, cemented it in place. Was an easy fix. I used a lot of tar (from a caulk gun type of tube). You are on the right track.
  3. steam man
    steam man
    Minister of Fire 2.
    NULL
    Jan 19, 2008
    652
    5
    Loc:
    Northern Maine
    I was just researching products for roof project and came across a pipe collar at: www.wilmarproducts.com. It just sides down. I am not sure if will fit over a no-caulk Oatey type flashing. It seems like it is just a flared adapter as opposed to the DWV reducer (which should work anyway).
  4. n1st
    n1st
    New Member 2.
    NULL
    Jun 3, 2007
    121
    0
    Loc:
    Enfield, CT
    Yes, mine dry rotted. A replacement boot would be just the thing. Where did you find it?
  5. n1st
    n1st
    New Member 2.
    NULL
    Jun 3, 2007
    121
    0
    Loc:
    Enfield, CT
    Steam man, thanks for the link, but it doesn't look like it'd fit.
  6. wahoowad
    wahoowad
    Minister of Fire 2.
    NULL
    Dec 19, 2005
    1,630
    132
    Loc:
    Virginia
    Mine came from Lowes
  7. Hogwildz
    Hogwildz
    Minister of Fire 2.
    NULL
    Nov 3, 2006
    8,021
    1,649
    Loc:
    Next to nuke plant Berwick, PA.
    That will work. Personally, I'd take the old one off and install a new one. The pipe collars come in a few sizes.
    Rule of thumb, one covers several sizes. Use the one that rated for that size or smaller. Never use one that made for a larger size than the pipe your flashing.
    Muck works, but does crack over time, makes a mess, and if you need to take it off, good luck. Its a PITA.
    Top 1/2 of collar at very least should be under the shingles. the bottom 1/2 or few inches on top of shingles. Exactly where depends on where the shingle courses are.
Thread Status:
