    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Drew1024 New Member
    Central NJ
    Good morning everyone!
    I have a few questions regarding my wood stove install. I am doing a vertical install through the ceiling, through a loft area and then finally out through the roof. My understanding is I can use single wall pipe up to the ceiling and then must convert to chimney pipe in the loft area even though it is still technically inside the cabin?? Secondly, I read that you can not use pipe from two different manufacturers that they may not fit properly? I bought a kit from Lowes that contains a ceiling support, attic insulation shield, stove pipe adapter, rain cap, and roof flashing. The single wall pipe is duravent from home depot and the chimney pipe is from lowes because it was cheaper. Thoughts? Will these systems be compatible? Am I missing anything else? Thanks so much.
    #1
    Helpful Sponsor Ads!
