Rutland Chimney Sweep Extension Rods
Jay106n
806
Litchfield County, CT
I plan on buying two packs of Rutland Chimney Sweep Extension 3ft rods, but they are at least $30.00 per pack (18 ft per pack). My question is how flexible are the rods? I have a high salt box type roof that I have no intentions of climbing therefor I would like to sweep from the clean out box in the basement where my stove is. Will the rods make the 45 degree turn up the flu?
If it's the same as the ones I use (likely is), I don't see it making a 45* turn.....never tried though.
Hmm ok.The product description says they will bend approximately 45 degrees.
HD had a few packages in stock, so I got 2 packs of the Rutland rods and a 8x12 brush, for about 90 bucks total. I gave the chimney sweep a go from the clean out box in the basement. The fiberglass rod on the 2nd attachment splintered and snapped in 2 almost immediately. My wife wont let me clean the chimney from the top down due to the high/steep roof and she doesn't want me dead quite yet, so I guess it is time to call a pro sweep. It is not a total loss though, because I still have an open fireplace on the 1st floor, which I should be able to sweep on my own from the bottom.
