I'm having a new problem tonight with my Quad 5700. I filled the stove as usual, brought the chimney flue up to about 550, shut down the start-up air(15 minutes as usual), and let the stove climb up to 500 degrees(on front door area) at full throttle for almost an hour. I tried to choke it down about half-way but lost my secondary burn. I opened the air controls again for ten minutes bringing the flue back to 550, tried to choke it down and lost my secondary burn after two minutes. the stove is at a solid 500 degrees and the chimney is only 300 and falling. I know the wood is fine but seems to smolder as I cut back the air supply. Could the chimney be blocked? I've never had a problem until tonight. The smoke appeared to be rising as usual...
