I'm looking for a stove for a small kitchen/bath space that I am finishing in a detached garage. The space is 12 x 25 (300 square feet). The space will be well insulated (spray foam walls and floor, the ceiling insulation is old fiberglass already). I'm thinking this space might be a little tough to heat due to the size, so my thinking was to find a stove that could light up well and then retain the heat and radiate over a long period of time. Looking to spend under $1500 on the stove. I am drawn to the Quadrafire 2100 Millenium and the Lopi Republic 1250. Someone will be home to stoke nearly all the time (work from home) and our sleeping quarters are in a separate building, so the temperature in this space does not need to be precise, but we will be wandering over to eat breakfast here in the morning so it would be nice if it was warm. The real dilemma seems to be a balance of holding heat for a while but not overheating the space too much. Would like a cooktop and oven space as well. How do these stoves fit, does anyone have opinions or use either and have pointers, and are there others you would suggest for this situation?
As far as retaining heat, I had the thought to build a cob structure around the stove once it is installed and a dome above hopefully to use as an oven. Is there anything I need to be especially aware of? Has anyone done this? Is it absurd?
thanks!
-Anthony
thanks!
-Anthony
