Hi,
We just bought a home with an MB-Solo. I am still not exactly sure which model. It looks like the one in the manual but not the one in the brochure (here).
http://www.woodboilers.com/products/discontinued-boilers.html
In trying to get it up and running I have discovered the 4-way auto mix is seized. I discovered this due to the motor attachment to the front of the valve being very hot. We have removed the motor attachment (reduced the risk of a fire) and have sprayed some WD-40 on the valve daily to try to work it loose.
A four way attachment is being used due to the wood boiler being used in conjunction with a propane boiler and a hydro-hearth in the main level fireplace (it still works). We plan to take the hydro-hearth out in the Spring and switch the 4 way auto mix to a three-way.
My question...the plumber believes that because the auto mix is sharing water between all three lines the boiler is safe to use for the short term...these next few months. While not as efficient it would save some money on propane. If the opportunity of some warm weather comes up before hand we can change out the auto-mix and dead-head the hydrohearth until its removal this summer.
Any thoughts? No one around Warriors Mark PA seems to service these any more. They seem pretty straight forward though.
Thanks
Thanks
