Yesterday morning when I went to load the furnace I noticed that my overflow bucket was full of water. When I came home, after loading I opened the boiler to see it full of charred logs. I went to the aqua-stat (Johnson Control) and turned the dial which immediately signaled the Belimo to open the draft, starting the fire. I kept my eye on this through the evening and and have concluded that when it temp threshold it reached (either high or low), it will shut down but not open (or vice versa) unless I turn the dial on the aqua-stat.
If anyone knows what is going on or has experienced this, I'd greatly appreciate your feedback. Not sure if it's the control or the damper actuator (Belimo) itself that needs to be replaced.
