    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Quincy New Member
    Ontario
    Has anyone switched boilers from a seton,greenwood style one burn chamber boiler to a newer gasifier boiler.Did your wood usage go down .Was the extra work of splitting the firewood into small splits worth it? I am simply asking if a newer gasifier is more efficient then the seton style boiler.Thanks for all replies.
    #1
    Helpful Sponsor Ads!
  2. Pat53 Minister of Fire
    UP Mich
    I've owned a Seton for about 4 years now and altho the unit works good for me, I don't think there is any question that some of the newer true gasification boilers would be more efficient. If I had to do it over again I would check out the Effecta. The EKO and Garn are also popular brands. The Seton is not gasification boiler, in spite of the claims that it is.
  3. 2.beans Minister of Fire
    new hampshire
    Why is it not a gasifier? I've had a seton for six years and like it for the ease of wood that you can burn in it but I do believe there are better boilers. That's why I purchased a used Garn. I Have no experience running the Garn yet tho.
  4. muleman51 Member
    SE Minnesota
    I'm on my first full year with my Empyre Elite after having an Adobe (Seaton knockoff) . Not sure that it burns less wood but at least you can clean it easier. It does a nice job of heating and it does keep my water closer to 180* and I don't need storage. I have a 1000 gallon setup for sale if anyone is looking. If I could start from scratchway back when I would go with a Garn. I have certainly paid for one with all my trying to save a buck.. Jim
  5. Jesse-M Member
    Columbia City, IN
    Mine gasifies.......and there is nothing better than throwing in large rounds and just quartering the really big stuff.
    No way id ever switch...
  6. BoilerMan Minister of Fire
    Northern Maine
    What is your desinition of gasification? I do think they run quite clean if they are connected to a significant heating load and run hot all the time, ie storage or large building with big heatloss and ample radiation.
    TS
  7. Quincy New Member
    Ontario
    Thanks for your input everyone.I presently have a 1000 gal storage to load up and system seems to fair pretty well.I have a hard time bringing storage to 180 as this might enable me to burn once a day ,verses twice dependent on weather of course.I heat storage to 160 and this works and has for the last 4 years.The large blocks are great to throw in,less wood handling.The primary and secondary firebox seems like a really efficient use of wood is this true or would I regret the extra work?My system is in a detached shed with 100 feet of buried 3/4 k-tec in 4 inch PVC duct insulated on the outside of the 4 inch duct with spray foam not ideal I know.Pat53 would you consider switching to dual firebox boiler and how much wood do you burn at what square footage are you heating?
  8. BoilerMan Minister of Fire
    Northern Maine
    To get a real comparison we'd need someone who had a Seaton and now has a downdraft gasser, with no other changes in building insulation/size. Don't know if it would justify the purchase of a new gassifier or not. Is your 1000 gallons pressureized? It seems if it were you should have no problem heating it to 180, and if it's an open tanks then HX may be undersized for the smaller delta t's expierenced at hotter tank temps. Are storage and boiler both in the shed?
    TS
