    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. neumsky Combustion Analyzer
    Oklahoma City
    My jotul does not keep the glass as clean when my fire's low as well as my PE spectrum which btw is a super 27 with a dress on. But...my PE also was harder to control hot fires...so I think your going to give and take with every stove. I would just buy one that your semi confident with and than...get the one you really want in 10 years or so. Like someone else said...their all pretty good. I keep thinking I should have gotten a BK...than I don't...than I do...than I don't...than I do. GO FIGURE!
    #26
    Helpful Sponsor Ads!
    Huntindog1 likes this.
  2. eclecticcottage Minister of Fire
    WNY
    We have the Lopi Repbulic in a 14x20 (or so) room and it doesn't cook us out unless we overfeed it during shoulder season. The Cottage is WAY smaller than your house so I can't really comment on heat transfer.
  3. farmer New Member
    se mn.
    Thanks for the comments. Has anybody had an epa approved stove used it for a few winters, then switch to a different brand of stove and could tell at the end of the heating season they used less wood?
  4. begreen Super Moderator
    South Puget Sound, WA
    Many folks have experienced that when they switched from a pre-EPA stove to an EPA stove, but I can't recall too many reporting a drop going EPA to EPA. That gets really subjective because of the variables in wind and temperature outside. I can tell you that we started using a little bit more wood when we switched, but that was to a stove twice the size. In return we got more even house temps and easy 24/7 burning on softwood.
    raybonz likes this.
  5. rideau Minister of Fire
    southern ontario
    Within the same manufaturer, drop in wood usage going from Cat Fireview to cat Progress Hyrid for the same amount of heat....definitely. It's more efficient, and that is saying something, because the Fireviews use very little wood compared to older and non-cat stoves. many have reported dramatic drop in wood usage going to cats and secondary burn stoves from pre-EPA...look at Backwood Savage's posts, for instance. I think his wood burning lore is pretty respected on this site....s
    Backwoods Savage likes this.
  6. raybonz Minister of Fire
    Carver, MA.
    You are correct cats and secondary burn stoves require about 1/3rd less wood than an old stove.. Even my old CDW cat stove made this claim and I heated my home on 3 cords a year.. Much better than 4-1/2 cords for the old stoves!
    Ray
  7. Backwoods Savage Minister of Fire
    Michigan
    From our pre-EPA stove (Ashley) to our Fireview, we cut our fuel needs in half but the biggest benefit is that we also stay a lot warmer now. Before we used to close off a couple rooms and we've not done that since getting the Fireview. Then last year we added insulation and put in new windows and doors plus an addition. With the warm winter and the added insulation we cut the fuel another 33%; that is, we were burning 3 cord before the remodel and last year we did 2 or a little under. We'll be curious what happens this winter.
  8. Pallet Pete Minister of Fire
    Ovid MI
    So far getting rid of our old us stove wonder wood we have gone from needing bout 8 full cord a winter to needing 3.5 to 4 cord average. The wonder wood was a box with a hole in the side and most the heat was gone out the chimney before the rest of the stove. It burned for about 1.5 hours between loads tops ! Our jotul which is a tube EPA stove goes 10 to 12 hours between loads so far and that's with a lot of coal left over for reload. We had a vogelzang Durango which was EPA listed and burned about 6 cord a winter give or take and we had to load it every 4 hours or so on really cold days because it was not truly air tight and would not have coal left over as well as it did not put off heat well.
    Pete
  9. farmer New Member
    se mn.
    What would look and hold up the best say I have this stove for the long haul,the normal finish they put on the stove or is it worth the extra money get an enamel finish?If i put a kettle of water on it wont it create a ring on the stove right away? Just want it to look nice down the down the road.
  10. raybonz Minister of Fire
    Carver, MA.
    The porcelain coated stoves look nice but not an easy fix compared to a painted stove which is easily touched up inexpensively.It all is a matter of taste.
    Ray
    Pallet Pete likes this.
  11. Woody Stover Minister of Fire
    Southern IN
    Those enamal stoves look really good, IMO...
    raybonz likes this.
  12. Pallet Pete Minister of Fire
    Ovid MI
    Agreed its a matter of taste ! They all hold up well if taken care off, everything needs maintanence. Paint is easy to touch up porcelain is expensive but looks beautiful and is easy to clean. We chose paint as it was cheaper and easy to touch up. The stove to us is beautiful for what it does heats our home, cooks our food and relaxes our cat lol.
    Pete
    raybonz likes this.
  13. raybonz Minister of Fire
    Carver, MA.
    I think they look good with paint too! Both look great to me and many like the flat enamel blue/black that Jotul sells. My 3 cats absolutely love to snuggle up the hearth when the stove is running and in the summer sleep on the hearth to stay cool! My cats are sleeping professionals if they were any more relaxed they'd be dead! ==c
    Ray
  14. Rich L Minister of Fire
    Eastern,Ma.
    When I sent my Fireview back I paid the shipping.They sent me the refund minus the shipping charge.
  15. begreen Super Moderator
    It depends on the stove you are considering. Many cast iron stoves that are enameled have a bare metal griddle top for this reason. On steel stoves the enamel is usually on the jacket, not the core stove. In that case you put the kettle on the trivet top or directly on the stove top. Regardless, it's best to avoid spills if possible. We haven't had one yet.
  16. Backwoods Savage Minister of Fire
    Michigan
    They all will hold up well. If you are concerned with the finish when you put that kettle of water on it, just put something between the kettle and the stove. For example, we use soapstone blocks to set all the pots and pans on when cooking or heating water.
    As for the finish on soapstone, if it gets scratched or something spilled so discolored, a light brushing with fine steel wool does the trick nicely.
  17. charly Minister of Fire
    Schoharie, NY
    First page you open up in the owners manual states they cover the return freight cost on the shipping. Maybe it's something they just started doing. You'd have to call and ask. If they were wrong I know they will make good on their promise.
  18. raybonz Minister of Fire
    Carver, MA.
    Charly even if you have to pay it's a good warranty or satisfaction guarantee. Personally I don't blame Woodstock if they want people to pay the return shipping. Some people would have the nerve to use the stove for free for 6 mos. then return it basically take advantage of Woodstock's goodwill policy. This could put a big dent in Woodstock's bottom line pretty fast considering the stove has to be overhauled and sold at a much lower cost so the shipping costs could compound the loss on a small company.. I was highly impressed with the company, the product and the people at Woodstock!
    Ray
  19. charly Minister of Fire
    Schoharie, NY
    I agree, they are super people and I for one would never take advantage of such good people. Hopefully people won't take advantage of their good nature.
    raybonz likes this.
  20. Rich L Minister of Fire
    Eastern,Ma.
    I never notice the shipping policy in the manual.It makes sense that the customer pays for the return shipping.I was thankful that they took the stove back.It's a wonderful policy.
  21. charly Minister of Fire
    Schoharie, NY
    I was surprised to see they paid for the return shipping myself. Can't treat your customers any better then that.
    raybonz likes this.
  22. neumsky Combustion Analyzer
    Oklahoma City
    It would benefit to put a small trivet under it.
