Side Trim Clearance Rockland 550
drwho
2
maryland
I would appreciate any help on determining the clearance for the side trim on the jotul 550. The manual states distance to side trim is 21 3/4 inches from centerline for 1 inch max thickness. What about pieces of trim greater than 1 inch. I can't believe anything thicker is considered a side wall. Can you use the same profile they give you for the mantle? I ask because my mantle side trim has some thicker trim about 5inches thick at the bottom which is 31 inches from center line.
Any suggestions
Yeah it exceeds the clearance by 10 inches, its just that it is more than one inch thick. If you apply the mantel profile it passes by a mile.
Thanks for your reply
