    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. troyce1 New Member
    Baltimore, MD
    I have a freestanding Treemont Wood stove that a friend gave me, and I am looking to possibly do to have the pipe go out the side wall of the building where we are installing it. Does anyone know what kind of pipe I need to buy, or installation guidelines to follow? I had posted here previously and someone directed me to a general woodstove guidelines manual, however, the piping instructions seemed very vague, and have installed a stove before so I am somewhat familiar with instructions.
    The stove takes an 8 inch pipe.
    Any help is appreciated.
    Thanks
    #1
    Helpful Sponsor Ads!
  2. joecool85 Minister of Fire
    Central Maine
    To pass through the wall and go outside you will need Class A metal chimney. Regular single wall or double wall stove pipe is for interior use only to connect from the stove to the chimney.
  3. troyce1 New Member
    Baltimore, MD
    Joe, so we could save money by running the single wall pipe inside and then prior to it passing through the wall, we would have to interchange over to the other pipe?
    Thanks for your reply.
  4. joecool85 Minister of Fire
    Central Maine
    As long as it doesn't pass through any ceilings or walls, then yes, you can save a lot of money running single wall as high as possible then switch to the pricey chimney Class A stuff.
  5. begreen Super Moderator
    South Puget Sound, WA
    I would strongly recommend downloading the installation instruction manual for the brand and make of pipe you intend to use for the entire system. This is important infrastructure that has to be done safely.
    Here is a link to DuraVent's DuraTech pipe installation as an example.
    http://www.duravent.com/docs/product/L150_Apr2011.pdf
