    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. wilbilt New Member
    Nor Cal
    I need to replace my door gasket (rope type).
    How is the 3/8"-1/2" 5/8" sizing figured?
    Width of door channel, depth of door channel, some other factor?
    #1
    Helpful Sponsor Ads!
  2. jtp10181 Minister of Fire
    Madison, WI
    The number is the diameter of the gasket....
  3. wilbilt New Member
    Nor Cal
    ...Right...but how does the gasket diameter relate to the dimensions of the mounting?
    Is there a "squish factor"?
  4. jtp10181 Minister of Fire
    Madison, WI
    I don't think it really does, you just need to know the right size for your stove. Ask Hogz all about that.
    Maybe take a piece to a stove shop? Could probably match it up.
  5. hearthtools Super Moderator
    There are different densities of the gaskets
    one 1/2 gasket will be Firmer than the next depending on the brand
    The density of the weave.
  6. wilbilt New Member
    Nor Cal
    I think the currently installed gasket is the wrong size. The manufacturer has been out of business for a long time.
    How to determine the correct size?
  7. pegdot New Member
    Upstate, SC
    Opps
  8. pegdot New Member
    Upstate, SC
    If the current gasket is of a size/density that it seals the door I wouldn't worry about what size the stove was designed for. A good seal is all you need. Take the current seal off and take it shopping with you. Still might take a little trial & error to get it right but you'll get there. Hands on comparison always works best for me.
    Peggy
Thread Status:
