Hi everyone,
I have a question about screwing together sections of SL-300 out venting pipe. The instructions (which are the worst instructions I've ever read) say to screw the outer casing together. The problem I see is, there are no "pre-drilled holes" as the instructions suggest. The only holes in the outer casing are where the tabs lock the pieces together. Is this where the screws should go? I will certainly take pictures if need be.
Thanks for taking the time to reply. I certainly appreciate it!
Craig
Craig
