    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. mbcijim Member
    Schuylkill County, Pa
    #1
    Helpful Sponsor Ads!
  2. mellow Minister of Fire
    Salisbury, MD
    Looks good, do you recall what that cost per watt?
  3. mbcijim Member
    $2.96/watt.
    Paid $5.50/watt 18 months ago for 200KW system.
  4. mellow Minister of Fire
    Salisbury, MD
    The gridsmart solar install you put up, that was quite a distance to that house, did you have to use a super heavy gauge wire to get that power back to the house?
  5. mbcijim Member
  6. mellow Minister of Fire
    Salisbury, MD
    You posted the correct one, I saw under the gallery owner another project that was done. Thought you were the gallery owner.
  7. mbcijim Member
  8. mbcijim Member
  9. southbalto Feeling the Heat
    Mid-Atlantic
    What's going on with the power generation? It looks like the system peaked out on the 19th.
    What should this system be capable of producing, in kwh, daily this time of year?
  10. mbcijim Member
    Clouds! That's what happens whenever it is cloudy. My first system is here, there is a lot more data in that one: http://live.deckmonitoring.com/?id=mbc_solar___bull_s_head
    You can see the cloudy days a lot more clearly (no pun intended) when you look over a month or year's data.
    It is pretty cool to be outside on a sunny day and know that you are manufacturing money with your solar.
    System #2 is forecasted to produce 108,000KW per year. Divided by 365, then penalize it for being short day's - maybe 250-280KW on a good day? I don't look at data on that small of a scale, just month's & years is all I care about so I don't have a better answer!
  11. southbalto Feeling the Heat
    Mid-Atlantic
    Really cool link.....thanks for sharing!
