Hi everyone.
We have a smokey basement from our oil furnace flue and our wood fireplace flue meeting at the exit point. Unfortunately, there is a cement cap above the two flues. We did have a mason build a wall between the two, but it hasn't eliminated the smoke. What is the next-best solution? Should I wall off the sides of one of them so that smoke only goes out (or air only comes in) from one side? This seems like it would reduce, but not eliminate the problem.
While the smell is annoying, is it dangerous?
Picture shows a side of the chimney with the brick wall dividing the two flues in the middle. I hope I am using the right terms.
![[Hearth.com] Smoke in the basement...can't raise flue [Hearth.com] Smoke in the basement...can't raise flue](https://www.hearth.com/talk/data/attachments/304/304817-e57fd9db14dd9ca57773524048342af5.jpg?hash=5of2xIr5v1)
![[Hearth.com] Smoke in the basement...can't raise flue [Hearth.com] Smoke in the basement...can't raise flue](https://www.hearth.com/talk/data/attachments/304/304839-ca90b8c9556db3cda5d7bf11340504f5.jpg?hash=X4_jUu4nw-)
