    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. BIGISLANDHIKERS Feeling the Heat
    I have a mt vernon ae. Has anyone else get any smoke ouside when running on higher levels. I don't get what I would call alot...just a little. Mostly notice it when I'm running on high. It's been enough over time to turn a large area of siding sooty.
    #1
    Helpful Sponsor Ads!
  2. hearthtools Super Moderator
    Try adjusting the air MORE AIR
  3. jtp10181 Minister of Fire
    Madison, WI
    You can't really adjust anything on the AE except the flame height and the fuel type unless there are some hidden features I don't know about.
    Rod I can't believe you didn't rant about the direct vent setup... as he has said many times with the direct vent setup you will get crud on the house. I always explain this to customers up front and if they don't mind it we will do it. If they don't want it they can pay for the extra venting to go up to the roof.
  4. hearthtools Super Moderator
    Im blue in the face saying over and over DONT direct vent
    LOL
    see the bottom of my help page
    Tips on if Your pellet stove is burning lazy and or getting smoke in the house
    http://www.hearth.com/econtent/index.php/forums/viewthread/13419/
  5. BIGISLANDHIKERS Feeling the Heat
    No there is no way to adjust the air unless flame height does that and I already have it at -5...the lowest setting. I believe this adjusts the feed rate. If I was to go all the way up my verticle would have been about 20 feet or more. My stove is in the basement.
  6. jtp10181 Minister of Fire
    Madison, WI
    How far out from the wall is the termination cap? You might be able to extend that a little to alleviate some of the soot buildup.
  7. BIGISLANDHIKERS Feeling the Heat
    About a foot of pipe and then the cap.
Thread Status:
