Recently installed a Napoleon 1900 in our finished basement. Fired it up for the first time last weekend, and it worked fine. We intentionally let the fire go out Sunday night. Logs burned completely down to ash. We had no smoke smell while it was burning, some pretty strong paint smell the first day as expected, but not a "smokey" smell. But now, 2 days later, when it's well out (cold, nothing but ashes in there), we have a VERY strong smokey smell in the basement.
My guess is, that while it was burning, the draft carried the smoke up and out. But now, the cool air is sinking down the chimney and carrying the smokey smell into the room. (Not smoke, just the smell) As far as I can tell the damper (on the stove) can't be closed completely, just stopped way down to LOW. I do not have a damper in the stovepipe. I read that you don't need one on the newer EPA certified stoves, which this is, as they have a built-in damper.
Is this normal? It smells like the inside of a smokehouse down there.
Should I put a pipe damper in? Do they seal the pipe that tightly?
Additional info, we had a new, insulated, stainless-steel liner (DuraVent) installed as part of the installation. Also, the house is less than 15 years old, and sealed pretty tight. So I guess we could be getting negative air pressure as well.
