Snap switch modifiction
bernie
2
I have replaced three snap switches on my Lopi insert. I am planing to instal a relay in line with the switch to avoid the high current through the switch.
What model stove is this?
I don't think a relay (contactor) will help, but I could be wrong. The snap action switches are rated for 25 amps or the ones I've used. If your blower is drawing more than that there is a serious problem. Most of those (blowers)are drawing from 1 to maybe 4 amps at the most. Those snap action switches should last for years. Maybe they are using some cheap OEM switches?
Agreed. Are the snap switches coming from a Lopi dealer? If they are the correct part, this could be a fan motor bearing going bad. When was the motor last lubricated?
