so how do I find a great stove in the off season when I CAN'T find one ever local
Jack Fate Posted By Jack Fate, Jun 23, 2013 at 9:05 PM
Thread Status:
  1. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    title says it all ,
    except;
    thought I wanted a cat stove ,now not so much,.if ever
    I got a good chimney ,masonry, two barrels ,2 stoves,SOLID
    SO GUESS want something that drafts well
    & IS SIMPLE
    I have a Fisher Grandpa & VC resulte problem
    8 yrs with them
    fisher eats wood like the government eats tax money
    VC Is maintenance is $$$$$$$$$$ & sucks life out of your time
    sorry venting <>
  2. Ram 1500 with an axe...
    Minister of Fire 2.
    NULL
    Mar 26, 2013
    2,327
    670
    Loc:
    New Jersey
    No, but good luck...
  3. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    Thanks
    With that and $12 I can get a a six pack of good beer want to know where to send the $12 to ?
  4. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
    South Puget Sound, WA
    There are lots of options. Tell us more about the space you are heating and more about the flue (height, liner or if not the tile dimension).
  5. StihlHead
    StihlHead
    Guest 2.
    NULL
    Online, I got my Englander 30 from HD online for $650 delivered here last year from VA. Non-CAT WA/EPA III approved, HUD approved, burns good, draft is fine with an OAK.
  6. alforit
    alforit
    Feeling the Heat 2.
    NULL
    Jan 30, 2013
    394
    148
    Loc:
    Western Washington
    Lol
  7. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    Replacing VC Resulte Want about 2 cuft stove needs to fit the old space , 8"x14 od tile, block & brick , located in center of 2 story home . 15 ' thimble to top with 9' below to clean out in crawl
    Stoves both on first floor
    Chimney in good shape , solid & no cracked tile
    Not interested in breaking out good tile / or any liner
    Chimney has drafted well for many years ( not broke don't fix it )
    NC 30 great value stove but too large , may be good Fisher replacement
    The VC heats house 95% of the time
    Use the big fisher about 2 wks a year
    Nearest HD is 100+ miles away ( that carry wood stoves)
    Most all other stove shops have only very $$$$$$ stoves in the size I need
    Then there is the WAF ; (
  8. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
    The flue system is marginal. It may work ok with older stoves, but most modern stoves require stronger draft. A liner would help.
    WAF is going to cost ya. Show the wife a Woodstock Fireview and the Pacific Energy Alderlea T5 and let us know what she thinks.
  9. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    WAF no to soapstone , me not gonna spend $ 6-12 K
    Just trying to keep it simple .
    One question though can an OAK be vented into a crawl space ?
  10. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
    Where does the 6-12K come from? A liner would be under 1K. No harm in trying the stove without the liner first as long as the chimney is safe. I am just passing along what is maybe the number 2 or 3 complaint with new stoves, poorly seasoned wood being the number one.
    http://www.chimneysweeponline.com/pacaldert5.htm
    PS: I feel for you ;lol , your wife and mine have something in common.
  11. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    Tile liner needs removed $$$ or rectangular liner $$$
    Not fond of the idea of bustin up good chimney
    Wife wants pro to do @ 4k estimate + stove
    I'm a DIY guy
    Don't like outsiders doing work for me , bad things & lawsuits
    Happen Always end up fixing their work
    And yes you don't need to sell the seasoned wood thing I already believe
  12. Woody Stover
    Woody Stover
    Minister of Fire 2.
    NULL
    Dec 25, 2010
    8,252
    2,334
    Loc:
    Southern IN
    Maybe you can slip a 6" liner up there without busting tile? No room for insulation, but the chimney is interior. If not, Homesaver rectangle flex? You can DIY for 2-4K depending on how good a stove you want.
  13. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,826
    9,890
    Loc:
    Northern Virginia
    Back in January you were getting smoke back from the VC. And at that time you said it didn't look like putting in a liner should be all that difficult.
  14. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    Correct , then found codes called for insulation , then tile needed removed
    Also after thinking about losing the heating effect of my brick chimney in the upstairs , well ?
    Got A catch 22
    I got 2 different stories from 2 different pros on codes
    And after reaserch found each had complaints against them
    Don't want a money pit happening
    I resealed my flue pipe & back puffing improved
    Also used old oak , although ash I had checked ok , but larger splits probably not
  15. StihlHead
    StihlHead
    Guest 2.
    NULL
    As for building codes: call or go to your county building department and find out from the engineers. Tell them you are designing a new house. Contractors may or may not have the latest and correct info. I got all the info I needed here for my remodel from the county that way. Did all the work myself.
    A cheap solution for you?: Try the Englander 13 NC. Nearly identical to the VC Resolute size. Smaller stove than the 30, same front/door size, not as deep, 1.8 cu. ft. box.
    VC Resolute Acclaim: Dimensions 25.5”W x 27.5”H x 25”D
    NC 13 Dimensions 25.0”W x 28.25”H x 25.25”D
    Go with HD online. They ship stoves, and last year I got free shipping here for my NC 30 from VA (3,000 miles away). This year home shipping is $99 for stoves, or free delivery to any local HD stores. NC 13 is $650 at most HD's online (you can select to purchase from any HD store online).
    OAKs are commonly vented from ventilated crawl spaces through the floor. Mine is. The keyword is ventilated crawl space. I find that it helps keep the crawlspace air drier, as the convection air flow works like a crawlspace fan system. It is also good to ventilate crawl spaces in this area which has high radon levels.
  16. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,354
    2,091
    Loc:
    Cascade Foothills, WA
    I also pull OAK air from the ventilated crawlspace. Works great all year to keep air moving through the crawl. I also believe that there is a supercharging effect since your OAK from below the stove contributes to the draw of the chimney.
    You don't have to insulate the liner IF your chimney is still in good shape. Only in the cases of a failed chimney must you insulate the liner since the insulation is taking the place of the compromised insulation offered by the chimney. Can't you just add height to the masonry chimey with more masonry? I'm a big fan of ripping down masonry chimneys in favor of far superior steel chimneys anyway but to save some cash....
    webby3650 likes this.
  17. DexterDay
    DexterDay
    Guest 2.
    NULL
    http://ashtabula.craigslist.org/app/3849564736.html
    http://cleveland.craigslist.org/app/3855140210.html
    Here are a couple. Don't know where in NEO you are? There was a Eng 30-NC for under $700 at the Ashland HD? A used PE Super 27 on CL a few months ago for a good price. They are out there, you just have to be diligent and check several times a day. When a good deals comes along, you have to jump! When sold, they get taken down. So if you only check on weekends, or every other day, you may be missing a lot.
    I have an app that alerts me to certain keywords, wood stove is one of them. I am always looking for a deal ;) I will keep my eye out and PM you any good ones. But what area are you from (just need the CL to search?) I normally search Cleveland, Akron, Mansfield, and Youngstown.
  18. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
    I'm not saying I know it won't work, it's worth at try to connect to the existing chimney and see how the new stove performs. My opinion is tha at about 80 sq in. I think the draft will be poor because that is almost 3 times the mfg spec.. I think this is what the Resolute is telling you. If performance is sub-par, a liner with maybe a 2 ft extension can make a big difference. Your estimates are too high unless there are serious confounding factors. What is the ID of the current clay tile liner? Sounds like it would be around 6.5 x 12.5" If so, drop a 6" liner down it for $500 and see how that works. If the clay tile is in primo condition I would skip the insulation at first and pour vermiculite later if desired.
  19. Woody Stover
    Woody Stover
    Minister of Fire 2.
    NULL
    Dec 25, 2010
    8,252
    2,334
    Loc:
    Southern IN
    With a two-story, sounds like he has like 20' of stack. Me, I would slap a liner in there and be done with it, regardless. Guaranteed great draft no matter the stove, never any smoke roll-out, safer setup, easier to clean, etc. And it shouldn't be too hard for a DIY guy.
    Be sure to post plenty of pics as you go. ==c
  20. mellow
    mellow
    Resident Stove Connoisseur 2.
    NULL
    Jan 19, 2008
    4,750
    654
    Loc:
    Salisbury, MD
  21. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    Thanks all ,
    One question if I put in a flex liner my chimney is 15' thimble to top . Do I need more height ? If so can a solid Extention be added to the flex?
    Thanks again
    About the time I get this figured out the WAF will kick in ; (
  22. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
  23. tekguy
    tekguy
    Feeling the Heat 2.
    NULL
    Nov 12, 2009
    368
    126
    Loc:
    west mass
  24. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    Yes 2/45's Are in the plan , are all double wall pretty much the same or are some better? Anyone chime in on menards dbl . Wall ? It's made in Canada . I have easy access to menards
    Maybe a small Extention pipe on top
    5' hangin out of chimney would look rather odd
  25. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
Thread Status:
