After burning wood for the first time this winter, I have been able to save about 250 gal of oil over this winter and I have been thinking of how to get my oil bill even lower. In my calculations, I burn between .75 and 1 gal per day in the summer for hot water. I have been thinking about adding some kind of solar hot water heater and really like the pages I have seen on how to do this for less than $1000.
I currently have a energy kinetics boiler with a superstor water tank for domestic hot water. I may be able to get another slightly used superstor tank and I was wondering if I could use it for a solar heat exchanger. (I think that is what it is called.)
What I would do is hook up the domestic hot water output of the solar superstor to the cold water input of the boiler superstor. This way, when hot water is drawn from the boiler hot water tank, it is being replace with hot water from the solar tank. If the solar tank hot water is warm enough - no oil needed to heat the incoming water. If it is not warm enough, hopefully it will be close so the boiler would only have to heat the water a few degrees.
Since the superstor would be free, all I would have to buy is the rest of the system. The bigger parts I would have to get would be the panels, the pump(s), and some sensors.
My questions are:
1. do you think this is possible/good idea
2. I live in the north east and if I wanted to run this in the winter, I would have to put antifreeze in the heat exchange loop. (Is this a good idea/possible?)
3. is it worth it to run it in the winter - temp on the cold days gets down to -10 (usually)
4. Any other parts (other than minor stuff) I would need.
The house is a straight face colonial with the south side of the house being the left side of the house. It has no windows on the first floor and I was thinking of putting the panels there. Minimally I would think that I could raise my well water from ~50 deg F to something a lot closer to what is in the boiler superstor - at least in the summer months and possibly in the spring/fall.
Thanks for any inputs.
My questions are:
