Whether a pellet is hardwood or a pellet is softwood will play no factor at all in determining the quality of your pellet. The two most significant factors in determining a pellet's quality are the cleanliness of the raw material (no bark, dirt or forieng debris) and the moisture content. Moisture is so often overlooked, and it is probably the single most important factor. Remember, when pellets are made, they are all compressed to the same density.just a question, which is better, i was told yesterday that the softwood is by far superior
Oil?...Yeah, Bertolli Extra Virgin- Love the damn stuff!Whether a pellet is hardwood or a pellet is softwood will play no factor at all in determining the quality of your pellet. The two most significant factors in determining a pellet's quality are the cleanliness of the raw material (no bark, dirt or forieng debris) and the moisture content. Moisture is so often overlooked, and it is probably the single most important factor. Remember, when pellets are made, they are all compressed to the same density.
I will hear some people say "my stove does not like softwood" and I will hear some people say, "my stove does not like hardwood." Neither is right, but based on their experience, they truly believe this to be fact.
If someone burns some crappy hardwood pellets, and then tries Okanagan or LaCrete, they will probably form the opinion that softwoods are better. Not necessarially true, but using the limited sampling pool that they used, it would seem like a reasonable conclusion. On the flip side, if someone burns some crappy softwoods, and then tries Somerset or Barefoot, they will probably draw the opposite conclusion. But in reality, most pellets, whether hardwood or softwood, have a density of somewhere between 41 lbs and 44 lbs per cubic foot, thus eliminating the hardwood vs softwood factor.
I'll give softies the cleanest burning title! Douglas fir has been the cleanest fiber I have seen at around 0.17% ash content. SPF comes in usually under 0.3% Size and density factor in with heat. So heat can be very close between them if they are compressed to the same density/similar size.
There is probably a good reason softwoods cost a bit more.
Yep...Since I turned 45, been pretty much softwood...OOPS, That's probably not what you're talking about!
I've had people tell me that their pellet stove manual says to burn only hardwood pellets. I was kind of surprised a stove manufacturer would say that.
Aren't pellets all the same??
The name is Greene Team. And the New England and Green Supreme are the exact same pellet....different bags.I've tried New Enland, Team Greene, Green Supreme, Maine's Choice. My favorite is Team Greene.
You don't say what kind of stove your running, hardwoods do just fine for me. But I've got an ash pan bigger than your head
Oh Lord, here comes the eternal feudjust a question, which is better, i was told yesterday that the softwood is by far superior
