sparks coming out of exhaust pipe
Courtney
54
Westminster, MD
Quadrafire Santa Fe. 2011 model. Freshly serviced and exhaust pipe cleaned. Using Cleanfire Pacific. Never noticed sparks coming out of pipe before....just occasional ones, but it is a concern.
Anything I have missed on care? Cleaned daily, full vacuum weekly. Run on high 15 min every day to clear any build up. Seems to be running optimally
thanks for any feedback-
Most stoves do it but most people don't notice it. That's the reason that vents need to terminate a certain distance above grade. It gives any sparks a chance to burn out before they hit the ground. As long as your stove and vent is installed to spec then I wouldn't worry about it.
Same here in Quebec, many models installed and they all do that but nothing to worry about.
When I ran short venting decades ago, I got sparks ocassionally and when I did, I backed down the compustion air a bit (slowed the combustion fan down). Don't get that anymore because my venting is over 20 feet vertical so sparks burn out prior to reaching the termination cap and fall back down in the ckeanout.
I would not be concerned about it so long as there is nothing flammable for them to ignite under the venting....
Never heard of that. What is it?
A bucket you put below the vent to catch the sparks,when the bucket gets full you recycle back into the stove :)
Reactions: JDenyer236
Sparks on snow no problem here
