Specifications Alderlea T5 & Jotul 550 Rockland
odd4even
1
Trying to decide on these two models. The specifications confuse me.
The Jotul 550 is larger, shows 65K BTU, heating capacity of 1,800 sq. ft, efficiency of 75%, and emissions of 4.5.
The Alderlea T5 is smaller (people say it uses Summit Box, but as far as I can tell, it does not), shows 34.6K to 72K BTU, heating capacity of 2,000 sq. ft, efficiency 82.6%, and emissions of 3.4.
Questions: Are these specs an accurate way of gauging the stoves abilty to heat? If there is not an industry standard, then it is comparing apples and oranges. If there is a standard, the Alderlea is a better stove. The Alderlea is significantly smaller, yet according to specifications it is more efficient, less dirty, and has more heating capacity. I guess I am suspicious that a significantly larger stove does not have the heating capacity of the smaller stove. I like the look of both stoves and simply want to buy the one that heats the best. Any feedback would be helpful.
I'm not too familiar with inserts as I have a freestanding Jotul. It is likely that Jotul overstated there firebox capacity in relation to the Alderlea. My F55 claims almost 3cu feet. The usable firebox space is just over 2 and a quarter. My opinion is that the T5 firebox has a tremendous reputation as well as regulated secondary air which I am a big fan of. My .02, go with the alderlea.
The T5 uses the Pacific Super firebox - 2 cu ft. It is closer to the C450 in size. The C550 has a larger, wider firebox.
Take a look also at the Enviro Boston or Venice 1700. It falls in between these stoves in size and has a good reputation.
