Steamer Kettle-rusty inside
cighon
34
Northern NJ
my steamer kettle is very rusty on the inside. does anyone clean them out our just let it be and keep adding water. if you clean it or paint the inside, what do you use?
also do you use a trivet under the kettle?
No trivet and just dump out whats loose. I do admit to cleaning (wire brush) and painting the outside every year or two, or as needed.
If it really bugs you, I s'pose you could try swishing a dilute vinegar solution around in it and dumping, rinsing and re-filling. Rick
you can season it just like a skilet
Hmmm....never thought of that. Wouldn't constant boiling water over a period of time take care of the seasoning though?
no you would want to bake it at 350 for 30 min rob it down with lard frist
Ya, that part I'm with, but after that, would boiling water (for the same reason you don't soak a cast iron skillet) ruin the seasoning?
clean it frist
