Steel stove temp????
ourhouse Posted By ourhouse, Oct 29, 2006 at 7:29 PM
Thread Status:
  1. ourhouse
    ourhouse
    Minister of Fire 2.
    NULL
    Feb 16, 2006
    727
    0
    Loc:
    Norfolk Ma
    I was wondering how hot I should run my stove at. The stove directions don't give any temps to go by. Is 600 degrees ok? Can I go hotter or is 600 to hot. Any help would be great.
    Thanks John
  2. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,889
    8,630
    Loc:
    South Puget Sound, WA
    500-600 is a good target temp.
  3. Roospike
    Roospike
    New Member 2.
    NULL
    Nov 19, 2005
    2,859
    3
    Loc:
    Eastern Nebraska
    To be honest i think it depends on the stove its self , size and how thick the steel is and at what house temp you are trying to maintain with different outside temp's.
    Wile running a smaller steel stove with a 2.0 cf fire box and the stove is made of 3/16" & 1/4" steel @ 550°
    vs a larger steel stove with a 3.0 cf fire box made of 1/4" and 3/8" at 550° is going to put out a lot more heat.
    It all depends on the size of the stove and the mass of the stove as to how much heat you need in your home.
    Your guide line is going to be the heat you need and not a set stove top temp.
    If you need less heat ... run it lower
    More heat ...run it hotter.
    You'll have to get to know you stove to determine how low you can go and get a clean burn and also how hot you can run your stove and no be over firing it all the time.
    The weather changes all the time as with the out side temps going from 50° to -20° and you would have a hard time keeping a set temp in your home with a stove that only ran at around 550°.
    The question you could ask your dealer or stove company is what is the max temp i can run my make and model of stove at.
    A wood stove is not like a house furnace .........
    You cant run the stove at say 550° all the time and when the house is warm to your set goal temp then the heat tuns off and then comes back on later.
  4. ourhouse
    ourhouse
    Minister of Fire 2.
    NULL
    Feb 16, 2006
    727
    0
    Loc:
    Norfolk Ma
    Thanks guys, I have been trying to figure it out. I just don't want to over fire anything.
  5. Sandor
    Sandor
    Minister of Fire 2.
    NULL
    Dec 9, 2005
    917
    0
    Loc:
    Deltaville,VA
    You could always follow the directions on my Regency stoves.
    If the top of the stove and stovepipe are glowing red, you are overfiring the stove! This is true! I overfired it once without damaging anything, but it was a scary sight.
    I would not think twice at running it at 700, if you need it. The heat difference coming off the stove from 600 to 700 is nothing short of amazing!
Thread Status:
