stihl chain saw
bobkupferer Posted By bobkupferer, Mar 31, 2008 at 7:42 PM
Thread Status:
  1. bobkupferer
    bobkupferer
    New Member 2.
    NULL
    Mar 31, 2008
    5
    0
    Loc:
    Louisiana Mo
    I have a Stihl wood boss 024 av chain saw. When I start it up the chain will not turn?
    I took the bar off and started the saw and the rear cog does not turn either?
    Thank you
    bobkupferer@gmail.com
  2. Mmaul
    Mmaul
    Minister of Fire 2.
    NULL
    Oct 10, 2007
    512
    3
    Loc:
    Muncie, IN
    You will have to take the "cog" off which is called the rim drive under that is the clutch that is most likely the problem. rim drive should be held on by a C clip and you may have to take some needle nose pliers and wiggle the drive off after the C clip is removed.
  3. kevin j
    kevin j
    Minister of Fire 2.
    NULL
    Jan 21, 2008
    607
    48
    Loc:
    minnesota us
    not to sound SA, but chain brake?
    might also be an additional brake lever on top of the handle. the later larger saws have that option.
    else, the clutch has issues.
  4. Mmaul
    Mmaul
    Minister of Fire 2.
    NULL
    Oct 10, 2007
    512
    3
    Loc:
    Muncie, IN
    You dont sound like a SA thats what these forums are for. More than one perspective. Good point on the chain brake.
  5. bobkupferer
    bobkupferer
    New Member 2.
    NULL
    Mar 31, 2008
    5
    0
    Loc:
    Louisiana Mo
    How can I tell if the chain brake is not working?
  6. Mmaul
    Mmaul
    Minister of Fire 2.
    NULL
    Oct 10, 2007
    512
    3
    Loc:
    Muncie, IN
    If it is the chain brake then its on that's why the chain isnt spinning, Sometimes you have to move the black hand guard forward and backward till you here a click and you will feel it slide up a little farther. Pull the hand guard back and push it forward with a little bit of force this should disengage the brake.
    MMaul
  7. bobkupferer
    bobkupferer
    New Member 2.
    NULL
    Mar 31, 2008
    5
    0
    Loc:
    Louisiana Mo
    Thank You how do I get the sprocket off to get to the clutch?
  8. Mmaul
    Mmaul
    Minister of Fire 2.
    NULL
    Oct 10, 2007
    512
    3
    Loc:
    Muncie, IN
    Take off the chain housing. what do you see is it an internal clutch where all you see is a gear or is it an external clutch where you see a nut and a round piece with springs?
  9. bobkupferer
    bobkupferer
    New Member 2.
    NULL
    Mar 31, 2008
    5
    0
    Loc:
    Louisiana Mo
    Does anyone know what size "C clip" is that is mentioned in this post.
    When I removed it it flew somewhere in my shop!
    Thank's bobkupferer@gmail.com
  10. kevin j
    kevin j
    Minister of Fire 2.
    NULL
    Jan 21, 2008
    607
    48
    Loc:
    minnesota us
    nope, but murphys law.
    been there, done that.
    Hold a hand or rag over them when popping off.
    Piston pin clips and broken rings also: stuff a rag in the crankcase as you ease the cylinder up before removing it totally.
    After 3 bankings that would do a pool shark proud, look for it in a place where it would do the most damage: down the open carb throat of a motorcycle engine, wedged between the primary gear and clutch hub of another mc engine on the bench, or into an electrical box..... :), then :(
    k
  11. Gooserider
    Gooserider
    Mod Emeritus 2.
    NULL
    Nov 20, 2006
    6,737
    10
    Loc:
    Northeastern MA (near Lowell)
    Note that many saw manuals warn against starting the saw w/o having a bar and chain in place - allegedly without the B&C;the engine can over rev and cause serious mechanical damage - including exploding the clutch w/ subsequent shrapnel exposure to the operator.
    The first check I would suggest (though it sounds like I'm too late) is to try moving the chain around the bar by (gloved) hand - if it doesn't move easily, check the chain tension; if it doesn't move at all, check the brake to make sure it's releasing. Normally the brake is pulled towards the top handle to release, or pushed towards the bar to engage - if it doesn't work properly, I would not use the saw until it's fixed.
    If you can move the chain by hand, but the engine doesn't move it, that points to an almost certain clutch problem, or possibly an assembly issue.
    Gooserider
  12. bobkupferer
    bobkupferer
    New Member 2.
    NULL
    Mar 31, 2008
    5
    0
    Loc:
    Louisiana Mo
    I would like to thank everyone who took the time to answer my post.
    The reason that the chain would not turn was the chain brake.
    Again, thank all of you very much;
Thread Status:
