Would double-walled fuel storage tanks be an option instead of using old propane tanks for water storage?
Normally fuel tanks are unsuitable for pressure storage. 25 psi doesn't sound like much, it can really distort a non presure tank though. The double wall should be some better although this was probably more for environmental safety than containing pressure, RandyMcKraut said:Would double-walled fuel storage tanks be an option instead of using old propane tanks for water storage?
maple1 said:For pressurized storage? No. I was wondering this myself so checked the tag on a double wall we have here. It had a pressure rating in Bars - got all excited there for a few minutes until I convert the Bars to PSI and it was only 2 or 3.
maple1 said:Ooops, guess my memory was worse than I thought.
It is in KPa, not bars - and only 7 of them.
Which is barely above zero on my pressure gauge - I didn't actually convert, I just looked on a gauge.
NCPABill said:Not much technical help, but I have an empty 500 gallon propane tank at 16933. I have $150.00 into it, and would part with it to a site member for that if you need it.
maple1 said:NCPABill said:Not much technical help, but I have an empty 500 gallon propane tank at 16933. I have $150.00 into it, and would part with it to a site member for that if you need it.
Feel like driving to Nova Scotia?
McKraut said:maple1 said:NCPABill said:Not much technical help, but I have an empty 500 gallon propane tank at 16933. I have $150.00 into it, and would part with it to a site member for that if you need it.
I'm on my way. That is a right turn when I hit Maine isn't it?
maple1 said:McKraut said:maple1 said:NCPABill said:Not much technical help, but I have an empty 500 gallon propane tank at 16933. I have $150.00 into it, and would part with it to a site member for that if you need it.
That's right - if you hit Cape Breton though you drove past me about 2 hours back.
Wouldn't want to put you out too much - so just call me when you hit NB and I'll come meet you there.
EDIT: I only wish I could find something like that 200 miles away - that's whatchya get for living in the middle of nowhere I guess.
