    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    I'm building an ICF (insulated concrete form) home in the spring. Several HVAC experts have warned me that this house will be so tight I will need an air-to-air heat exchanger (already planned) and a sealed-combustion wood stove (not planned...). Help! Who makes such an animal. BTW, it's going in the living room, not the basement, so don't tell me about a whole-house solution that I have to go outside to feed.... The closest I've come to finding one is mention of kits for some brands that will allow connection of a combustion air feed.
    Answer:
    Stoves with an external air feed should do the job for you. If there is enough air for normal living then there should be enough for these stoves. The exception might be if you were to want a stove with doors that stay open for viewing, but this is probably not a good idea for your application.
    Many, if not most, stoves built today have outside air attachment.
    #1
    Helpful Sponsor Ads!
Thread Status:
