    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. save$ Minister of Fire
    Chelsea Maine
    I have a prefab fireplace which I would like to be able to use for some real heat. While I do have a furnace and a pellet stove, they are useless when the power goes out. I have been considering putting something in the fireplace, but would like something fairly clean. I have seen some of the gas inserts and also seen some fire log sets. Both claim to put our about the same amount of heat. Comments??? thanks
    #1
    Helpful Sponsor Ads!
  2. jtp10181 Minister of Fire
    Madison, WI
    gas logs are decorative, unless you get a vent free set. Direct vent inserts would be your safest, and most efficient end result.
  3. Fsappo New Member
    Central NY
    If you are ONLY looking for heat when the power goes out, vent free logs are your most cost effective. Do you run natural gas or lp?
  4. save$ Minister of Fire
    Chelsea Maine
    We only have access to LP in this area. Cost about 2.50 I have been told.
  5. Fsappo New Member
    Central NY
    Id use the VF Logs then, for emergency heat
Thread Status:
