Stove pipe paint
Kenster
1,705
Texas- West of Houston
We have 15 feet of stove pipe/flue between our VC Vigilant and the ceiling. The black paint on the pipe could use some dressing up. Is there a preferred black hi-temp paint for this job? I'll want to brush it on. My Bride will make herself a widow if I try to spray paint in the house and I sure don't want to dismantle it to take it outside to paint.
After that, I'll probably need to hit the stove with some Rutland's.
Thanks!
Thanks!
Rutland and a few other manufactures offer brush on high temperature paint.
Will it work on stoves? Right now my defiant is a different color from my stovepipe. The stovepipe is brand spanking new, the stove is used.
Then again my wife has been complaining about not doing the stone facade yet.
Thanks!
This is what they recommended by Lopi for our Liberty.
http://forrestpaint.com/index.php?page=hi-temp-paints
zap
Thanks!
I never use paint, most stove shops have a black wood stove paste that you just rub on like you were waxing a car.... it takes care of rust but does not hide blemished as good as a solid paint, but makes the stove and pipe look nice... you can apply several coats and usally is good for a few years....
Thanks!
John, you're saying I could use the same product - stove paste or stove and grill polish, to dress up the sheet metal pipe/flue? I'd be good with that if that will work.
Kenster said:
Thanks!
I have used it for 30 years to give the stove a nice cllean look, it will have a little burn off smell, but a paint would also... I runs less than $10 a tube,,, use latex glove or you will end up with black hands and apply with cotton rag while the stove is cooled down...try it out on the back of side to see if you like it... you can apply as many coats as you want.. after application give it a good buff....
A quick note here, Stove Brite paints are NOT compatible with some stove pipe paint. I found this out the hard way with our Simpson DVL (double-wall) stove pipe. It causes the factory paint to bubble and wrinkle. For this pipe use a non-acetone based paint like Krylon High Temp.
