Stove runs better with ash pan open
rcracing17
12
07848
hey everyone. My enviro ef3 insert seems to have a much better flame when the ash pan door is cracked open. With it shut I have a small flame not really coming out of the burn pot. With it open, it's a nicer, brighter flame maybe 3-4 inches above the burn pot.
What would be the issue I feel like it should burn like it does but with the ash pan door closed.
All motors were cleaned and stove was thoroughly disassembled and cleaned before starting it up yesterday
Not familiar with your stove, but it sounds to me like its not getting enough air and opening the door is allowing more air into the firepot. Is the stove new (or new to you)? Is there an OAK installed? Again, not being familiar with your stove, I'm assuming the air for the fire comes through ports in the firepot, are these ports clear of ash and debris?
Yes I have a oak installed. I ran it from the chimney clean out door to the stove. Adjusting the damper doesn't seem to make a difference to the flame
Check your damper setting (it may have been inadvertently moved during cleaning speaking of which did you clean the crud out of the chimney?) and air intake for possible blockage however, you really need to set the draft with a Dwyer Gauge by the manual and not look at the flame height as the end all.
Chimney was cleaned. I tried playing with the damper. All the way in. Half way. All the way out. Makes no visible change. I'll take the brick panel off this afternoon. Mabye something shifted while I was moving the stove back inside to its place
I would look for the damper maybe not moving when you think it is, they have been known to come loose and also to not always close down enough. But there is more than just flame height to look at.
