    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Bmdoss New Member
    Missouri Ozarks
    What's everyone doing for protection from lighting? We get a lot here in MO. I am looking to better protect my well pump. I may just start throwing the breaker during storms
    Sent from my SGH-I747 using Tapatalk 2
    #1
    Helpful Sponsor Ads!
  2. Frozen Canuck Minister of Fire
    Google whole house surge/lightning protectors. A little pricey but then everything is protected.
  3. seige101 Feeling the Heat
    Palmer, MA
  4. jharkin Minister of Fire
    Holliston, MA USA
    Throwing the breaker won't help if the surge travels the neutral. In addition to the unit siege mentions they also make whole house protectors that fit in a double breaker package. Lower surge rating but faster reaction time and you don't loose circuits.
  5. semipro Minister of Fire
    SW Virginia
    I'm not sure anything I've seen mentioned so far will help with wells.
    I suspect that lightning strikes to trees or the ground near the well pump's underground power feed wire, or even the wellhead area itself, may be the most likely cause of pump failure, not strikes at the house that feed through the breaker panel to the well pump.
    If I'm right it would seen that some sort of surge protector installed near the well itself might help.
  6. woodgeek Minister of Fire
    SE PA
    I've got one of those double-slot breaker box guys and have had no problems. If you're comfortable in the box, an easy DIY.
