What's the best way of doing this? Can I put the legs on while the pedestal is still attached? Or is this going to require me to deadlift yet another stove?
Well, crap.
You should be used to dead lifting stoves by now. Can you wedge a dolly under one side, lower the dolly horizontal, and have your wife stand on the very end of the dolly? That should give you enough to get the one side on. Repeat and put a jack under the other side with a board over the top of the jack to better distribute the weight and protect the stove. Then once the legs are on, lower the jack and voila...
Legs look better than pedastals in my opinion. The only pedastals that I like are the ones that have wood storage, and only some of those.
You must be fairly strong. Woodstoves are certainly heavy. I have that Heritage sitting in my lobby and it's funny to see people try and move it. They have no clue.
Got an engine hoist and some straps?
I laid mine all the way back on its back.. Doing it on an appliance dolly would make it easier....
Definitely a no go putting the legs on with the pedestal on..
If I remember correctly, I took out the fire brick and removed the door and ash pan from my Englander 30. This greatly lightens the stove. I then flipped the stove on it's side and removed the pedistal and installed the legs. BTW, keep the pedistal installed as it makes hauling the stove around on a dolly easier when going from the trailer to the hearth.
Good luck with your Englander.
Bill
Mine, from Home Depot, was on a pallet when they delivered it. I unpacked it and took it off the pallet on the back patio before I moved it around.
