    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Mumster New Member
    Western MA
    I was wondering what people use for fan settings to get the most heat. Let's say I have perfect wood, draft etc. if I am all the way closed with a good fire going. Seems to me with the fan on the highest setting wouldn't the insert run at a lower temperature cause the room air is cooling the stove off? So when the fan is on low the stove is hotter? I know, I need a thermometer.
    #1
    Helpful Sponsor Ads!
  2. wjb111 New Member
    Michigan - United States
    We have been using our new T5 for about 3 weeks now. I also don't have a thermometer since the only place to put the darn thing is next to impossible to see. You have a valid point with the fan on high causing a lower stove temp. In my opinion, it seems to generate more heat with the fan on high vs a lower setting. I don't believe the fan on high causes a lower stove temp but again just my non-expert opinion. At times the blower on high can be a little annoying so I will back it off to about half way. Yes quieter but doesn't seem as warm in the room.
    :) :cheese: :coolsmile:
  3. Doing The Dixie Eyed Hustle Minister of Fire
    Ridge, LI, NY
    Yes, you do :)
    Welcome to the forums :)
    Adding your stove info to your signature line will be beneficial, as well as adding your general location to your info. We do aim to please :)
  4. Mumster New Member
    Western MA
    Thanks for the "warm" welcome. ;-) The manual says the optimal setting is L on the damper and low on the stove.:-/
