Talk me out of this splitter if I shouldn't buy it.
stonehouse Posted By stonehouse, Dec 29, 2007 at 11:43 PM
Thread Status:
  1. stonehouse
    stonehouse
    New Member 2.
    NULL
    Oct 29, 2007
    80
    0
    Loc:
    Hudson Valley
  2. Lignums
    Lignums
    New Member 2.
    NULL
    Oct 14, 2007
    181
    0
    Loc:
    Cincinnati
    Yup. I got mine, a 27 ton Yardmachines splitter with a Honda for 600, but I had to do some work to it. The knobs a Home Dumpo brought a fork lift down on top of it, and bent up some stuff, but hey, never a problem yet. It's a good machine, and will serve you perfectly. I have only had one piece of wood get stuck, and that was a hardcore crotch of Elm. Elm sucks , but it was relatively the same as anything else I have split with that machine.
  3. stonehouse
    stonehouse
    New Member 2.
    NULL
    Oct 29, 2007
    80
    0
    Loc:
    Hudson Valley
    That;s a lucky score.
    I think mine is too.
    Good
  4. burnham
    burnham
    Member 2.
    NULL
    Oct 19, 2007
    164
    8
    Loc:
    central massachusetts
    Same splitter here, works very well.
  5. velvetfoot
    velvetfoot
    Minister of Fire 2.
    NULL
    Dec 5, 2005
    9,431
    711
    Loc:
    Sand Lake, NY
    Make sure it runs well, like the engine wasn't run sans oil.
    It seems like a good deal to me.
  6. MrGriz
    MrGriz
    New Member 2.
    NULL
    Oct 11, 2006
    1,022
    0
    Loc:
    Waterford, WI
    If it has really never been used or run, it sounds like a good deal. I would ask for the story behind why he is selling it; even though it'll be a story. I would also check it over very well, since you won't be getting any warranty with the unit.
    You should be able to buy that or a comparable unit for about $1,000.00 if you watch for sales. So, you're basically saving a couple hundred in trade for a warranty.
  7. stonehouse
    stonehouse
    New Member 2.
    NULL
    Oct 29, 2007
    80
    0
    Loc:
    Hudson Valley
    Story was, they guy was going to start a firewood business with a friend and the friend backed out.
    It's brand new, never run.
    The gas tank was dry, never had anything in it.
    I haven't run it yet cause of the holidays but I'm confident it'll be no problem.
    Thanks all.
  8. BurningIsLove
    BurningIsLove
    New Member 2.
    NULL
    Jan 4, 2006
    353
    0
    Loc:
    Billerica, MA
    Does it have a suspension system in the axle/frame for towing? I have a HF splitter that is DOT rated for 45 MPH, but it lacks a suspension. As a result, it has to be towed on near-perfect roads w/o potholes else it jumps into the air. It jumped so much it cracked the weld from the fluid tank to the frame and leaked.
  9. Cath
    Cath
    Feeling the Heat 2.
    NULL
    Jul 31, 2007
    295
    1
    It may be an even better deal if it's still under warranty. I took a quick look at the MTD/Yard Machine website and it looks like that might depend in part on whether "Yard Machines" is an independent label.
    I'd ask if the guy has the proof of purchase / receipt and the owner's manual. If it's still under warranty you might need those to enforce it. Check now to see if you need to take special steps to actually transfer the warranty.
    ~Cath
Thread Status:
