Tarm shutting down during startup
penfrydd Posted By penfrydd, Nov 6, 2011 at 10:59 AM
Thread Status:
  1. penfrydd
    penfrydd
    New Member 2.
    NULL
    Jul 7, 2008
    77
    0
    Loc:
    Western MA
    Scantec (Tarm) Solo 40 once in a while shuts down during startup; usually after all the wood is loaded and there's a decent bed of coals. Once I turn the fan back on, it runs fine. I'm assuming that the exit temp is shutting down the system and that I simply need to do the start up procedure a bit longer?
    penfrydd
  2. Fred61
    Fred61
    Minister of Fire 2.
    NULL
    Nov 26, 2008
    2,095
    400
    Loc:
    Southeastern Vt.
    I don't know about the Tarm but my eko with the ekoster 2 controller has a "start" cycle which will shut down the boiler if it has not achieved 70 °C in a given amount of time. It's been so long since I've read the manual, I don't know if the temperature or duration is adjustable. Whatever mine is set at works fine for me. several small splits loaded to a level just above the bottom of the door opening starts going pretty fast.
  3. NHFarmer
    NHFarmer
    Feeling the Heat 2.
    NULL
    Feb 17, 2008
    290
    2
    Loc:
    southeastern NH
    If I push it too fast I have had the same problem. Just get it going good before you load it up and you should be good to go.
  4. jebatty
    jebatty
    Minister of Fire 2.
    NULL
    Jan 1, 2008
    5,355
    701
    Loc:
    Northern MN
    This perplexes me. I've never had this happen, now entering the 5th heating season. I assume when you say "when you turn the fan back on" you mean that you have to reset the Solo 40, right? As best as I know this only happens when the sensor in the smoke box cools below the setting on the dial under the cover and on top of the controls. It seems odd that with a bed of coals, fire start-up, this would happen, but I suppose it could if you failed to get a good fire going, hot enough to engage the shutdown control, and then the smoke box cools down to shut off the draft fan.
  5. penfrydd
    penfrydd
    New Member 2.
    NULL
    Jul 7, 2008
    77
    0
    Loc:
    Western MA
    Jim, This was my assumption as well; that the fire just wasn't hot enough to keep the sensor satisfied. However, if I'm around when it happens, it certainly seems like the fire is going just fine, when I open up the door. It's not like I ever have to rekindle the fire...
    I was just wondering if others had experienced this.
    Penfrydd
  6. Fred61
    Fred61
    Minister of Fire 2.
    NULL
    Nov 26, 2008
    2,095
    400
    Loc:
    Southeastern Vt.
    From what you are saying, there seems to also be a time element in the control like my eko.
  7. NHFarmer
    NHFarmer
    Feeling the Heat 2.
    NULL
    Feb 17, 2008
    290
    2
    Loc:
    southeastern NH
    If I start from scratch with a kindling fire, then toss in a couple of larger chunks and walk away the temps will come up and then drop off and shut the blower down if I don't pay attention to it. If you have already started a fire and have a good bed of coals it should not shutdown. What are your flue temps like when you have it shutdown?
Thread Status:
